So, apparently I didn't learn very much about tools or fixing the house when I was younger.
Here is what I need to do. I need to install three binding post plates. I am installing one with two sets of outlets that will connect to binding posts in the other side of the room where I will connect my rear speakers for my HT. I am planning on running wire through the crawl space under the floor.
In the spots for the rear speakers, I pre-drilled holes on the boards between the studs and the floor, exposing the crawl space, so that I can guide the speaker wire up there.
Anyways, what types of tools will I need for this project? What would be best to cut the drywall? Is there any easy to make mistakes that a noob would make that you can advise to avoid?
Any help would be appreciated!
Thanks.
Thanks.
