Brad Newton
- Aug 14, 2001
please explain "dts 96/24". Is it only for sacd or dvd audio or is it used in dvd (movie) playback?
Does the Pioneer 45 or the Sony 4ES decode this format?Yes, according to http://www.dtsonline.com/home/faq.shtml it is fully compatible with existing decoders.
Now I don't know if the 4ES or Pioneer 45 are able to get 96/24 out of it, or if they're decoding it to 48/16.
Seth
DTS-96/24 is completely a different codec from DTS you cant just add data to make it an uncompressed signal it has to be a completely different stream/codec.
8. What is 96/24?
More recording is being done at a 96kHz sampling rate and at 24 bits. DTS has always had 24-bit capability, and DTS 96/24 adds the 96kHz capability. It is fully compatible with existing DTS decoders, which will output 96/24 tracks at 48kHz. DTS 96/24 is the only system that:
- provides 5.1 channels of 96/24 along with full-motion video on DVD-Video and DVD-Audio (video zone),
- is compatible with all DVD-Video players, and
- is accessible through the digital output.
9. How Does 96/24 Work?
The DTS coding system has a “core + extension” structure. The “core” represents the DTS data as has been known since the first home decoders. The “extension” can carry data for future applications or enhancements of any sort. All DTS decoders recognize and use the core data. Basic decoders ignore the extension data, while advanced decoders can make use of it. This allows for full backward compatibility for any scheme using the extension. DTS has recently used the extension field for two purposes. In the first case, it has been used to carry an additional channel for 6.1 dis-crete. In the second case, the extension field carries the additional spectral data added by 96-kHz sampling. For a program in DTS 96/24, existing decoders read the core at 48-kHz and reproduce the standard spectrum. DTS 96/24 decoders read both core and extension and reproduce the extended spectrum. The data rate for 96/24 is 1.536Mbit/s, the higher of the two DTS rates presently used. While numerically this might suggest twice as much compression, there is in fact negligible additional compression on the core data. This is because there is relatively little information in the range 24-48kHz, so it can be coded very compactly. The 96/24 stream passes through the S/PDIF just as standard DTS does.So the normal section of a DTS 96/24 track is "native" 48/24 DTS, with the extension space carrying additional information to provide 96/24 output. Still compressed, though.
