Help a complete (not quick lerner) newbie (1 Viewer)
josephnyc
Joseph
Hi,
Please excuse this absolute newbie post.
I have extensive experience with computers and wiring, some with electronics, and plenty with consumer electronic, but very (very) little with home theatre.
This is for my own place.
I visited a friend yesterday who has a Panasonic 58" Plasma, a Denon rcvr and a Control4 controller and was blown away.
I'm ready to scrap what I have now.
What I want is a big (58" or 65") plasma (maybe the TH-65PZ750U or the TH58PZ700U), with a receiver, CD, DVD player that also plays my many thousands of MP3's.
The MP3's are already on a network accessible NAS drive.
The location for the system is already wired for power, ethernet and speakers.
Can I simply get away with a Panasonic Plasma, a Denon AVR-3808CI receiver, and a DVD-2930CI DVD player?
Will this setup allow me to play my NAS-residing audio files well?
Will it display and let me browse/select the file/song info on screen?
Can I use my existing speakers (front set: Bic DV62si; rear set: Polk model S4; no front/center speaker to speak of; subwoofer)?
Will a drywall on metal studs wall hold the nearly 200lb TV?
I'm using RCN cable now (digital, HD), but will hopefully be switching to Verizon FIOS when available. Does this play a role?
Do I need a controller like Control4?
Thank you so much!
Joseph
Phil2B
Phillip
It sounds like you have a good base to start with. When hanging a TV on metal studs I would cut out the drywall from stud to stud ( TV will hide this) so you can pre-drill holes for bracket and use Nuts and bolts to secure not the supplied lag bolts. You will enjoy a control4 controller just be sure you get a good installer who understands networking. As of now C4 only supports WEP so you might want to create a second network for the automation system if you prefer WPA for your computers.
CB750
Bill
After you get your TV set up and are happy with how your existing speakers sound you are going to want to invest in a Center speaker that is matched to your Polk 54's. So much of the HT experience is delivered through the center channel. If you bass is lacking then add a Sub.
TheThrillisgone
