Bill Will
- Dec 26, 2001
A freind of a friend wants to buy a JVC Receiver & he can't be talked out of it but he can only afford the RX-8020 or the new RX-8030 & he really wants the 8030 but he is affraid that it won't be able to handle his 4ohm speakers (I'm told they are Big 4ohm Towers) but the 8020 can & has that 4ohm/8ohm switch on the back. JVC Rates the 8020 at 100 watts X 5 & the 8030 at 130 watts X 6
Do you think the 8030 would be able to handle a 4ohm load?
What if he din't use the 6th back channel would that make any difference? Thanks
I've also noticed that Most lowered priced receivers, besides Panasonic, can no longer handle 4ohm loads?
