Hi all,
Do I have any options to get 2-tuner PIP to work when using digital cable. I don't believe my box has a composite video out to connect to a receiver either. Also, my tv has only one coax connection. Is there any way to get PIP to work with this setup?
Also, if I have my cable from the wall going into the cable box and then from there to the tv, would a power surge destroy just the cable box or would it also make it to the tv?
Naddy
Naddy
