Heatshrink question...
Discussion in 'Archived Threads 2001-2004' started by Ari, Sep 29, 2002.
  1. Ari
    Ari Stunt Coordinator
    Aug 3, 1999
    202
    I'm in the process of ordering materials for some DIY interconnects. I have my eye on some 3:1 heatshrink and I have some questions. Does the heatshrink shrink lengthwise as well?? I know that the diameter will shrink to fit the diameter of the cable but will it get shorter as well?? What's a good length to use??
  2. Jason Charlton
    Jason Charlton Ambassador
    May 16, 2002
    3,557
    414
    4,110
    Baltimore, MD
    Jason Charlton
    Hi Ari, and welcome to the wonderful world of DIY interconnects. To answer your question, the tubing does not noticeably shrink in the lengthwise direction. I ordered my 3:1 tubing from PartsExpress (I think a lot of folks here use the same stuff) It's great because you don't need a really high temperature heat gun to shrink it - a hair dryer works just fine. It comes in 6" lengths (12 mm diameter for individual cables), and I usually cut it into thirds (2") for the ends of my interconnects - though some folks might prefer a slightly longer or shorter look. Hope that helps. Good luck with your project.
    Jason
