HEAT is available in DTS DVD!
Discussion in 'DVD' started by YANG, Jan 29, 2002.
  1. YANG
    YANG Second Unit
    Feb 10, 1999
    471
    2
  2. Julian Lalor
    Julian Lalor Supporting Actor
    Oct 5, 1999
    975
    A Panavision film with an aspect ration of 1.85:1. I don't think so. Give me 2.35:1 and a perfectly adequate Dolby Digital track any day.
  3. Dave H
    Dave H Producer
    Aug 13, 2000
    5,540
    177
    I agree with Julian. Also, I would appreciate more detail in the title specifying that it is not Region 1. Thanks.
  4. Gareth Flynn
    Gareth Flynn Stunt Coordinator
    Oct 15, 2000
    83
    As much as I like DTS, OAR is a lot higher on my list of priorities when I buy a DVD.
  5. Jerry Gracia
    Jerry Gracia Supporting Actor
    Oct 20, 1998
    534
    Oookaaaay...
  6. John DeLuca
    John DeLuca Stunt Coordinator
    Nov 22, 1998
    120
    I'll keep my R1 version. The comparison picture in the review just made up my mind right there. Sure, the sound might be great, but there's alot chopped off the sides of that picture.
  7. Joshua Moran
    Joshua Moran Supporting Actor
    Apr 11, 2000
    502
    I agree with Gareth. OAR is much more important to me than sound. Granted I would love to have this movie in an explosive DTS track but thats what fantasies are for. Also being that this is a Region 0 disc it leads me to suspect it may be a bootleg.
  8. rutger_s
    rutger_s Supporting Actor
    Jul 7, 2000
    878
    Its not a bootleg DVD.
    The disc is distributed by Bitwin. A Korean distributor who prefers to not include a region code on their DVDs. Bitwin also distributes Belphegor: Phantom of The Louvre & La Apartment.
    The only reason I do not want to pick this up is due to the cropped AR on the dts disc.
  9. Chad B.
    Chad B. Second Unit
    May 16, 1999
    279
    I own the Korean release and while I hadn't heard of the improper aspect ratio issue until it was too late to cancel my order, I can say for certain that the dts track rocks!
  10. Roger Mathus
    Roger Mathus Supporting Actor
    Sep 1, 1997
    548
    Central Oregon
    Roger Mathus
    I also own this Korean disc. Actually it is a 2-disc set. Both are anamorphic and dual layer. The first disc is DD5.1 sound and a 2.35 aspect ratio transfer. The second disc is dts and 1.85 aspect ratio. I have found Bitwin products to be of consistently very good quality. I only wish they had paired the dts with the 2.35 aspect ratio video.
  11. Gareth Flynn
    Oct 15, 2000
    83
  12. Tom-G
    Tom-G Screenwriter
    Mar 31, 2000
    1,638
    2
    Pittsburgh, PA
    Tom G
    Indeed it is bizarre. If the movie is going to be letterboxed, why not the proper aspect ratio? I would have purchased this in a heartbeat had it been OAR.
    I'm curious though--how does the DTS track compare to the DD track on the laserdisc? I have both the LD and DVD and the sound on LD is incredible and noticeably better.
  13. Roger Mathus
    Sep 1, 1997
    548
    Central Oregon
    Roger Mathus
    Not so strange. 16x9 TV sets are likely more common in Korea than in U.S. as they have been marketed for several years. There are some 16x9 set owners who do not like black bars and want the picture to fill their screen. I think that the OAR issue will live well into the 16x9 era. The majority of widescreen titles releaed in Korea, however,seem to be OAR from what I have observed.
  14. Julian Lalor
    Oct 5, 1999
    975
    It is odd, though, that they used the DTS track with the pan and scan version of the film and not the DD track, if they were concerned about consumer complaints. I would have thought vastly more people would be able to watch a DD version of the film than a DTS version, given you need a DTS decoder to listen to the latter. You'd think someone with a high end audio system would be more interested in the OAR. Very wierd, particularly as this is a pan and scan not open matter version of the film, as it was made in Panavision not Super 35.
  15. Michael St. Clair
    May 3, 1999
    6,001
    Black bars compress easily, hence it makes more sense to put DTS on the 2.40:1 disc, there will be more room at the same picture quality!
  16. Marty Lockstead
    Marty Lockstead Second Unit
    Mar 4, 2002
    275
    Figured it was time to update this old thread with some new information. www.thedvdetective.com has a listing for an R2 dts edition that is anamorphic, unfortunately, I can't tell what the aspect ratio is by looking at the back cover of the photo they show. But isn't there a special edition coming out soon on R1 sometime this year?
  17. Moz
    Moz Agent
    May 19, 2004
    32
    Hi,
    I've got the R2 Japan version, witch feature a stunning 2.40 frame and offers a DTS track.
    I 've tried my old LD with this wonderful DOLBY DIGITAL track and i must admit that the new japan DTS version is not better !
    It felt a bit front heavy and less opened in fact... in comparison.
    As a result i would tell, keep your LD, it's a winner !!!
    Compared to the DOLBY tracks existing on the different DVDs around the world, this DTS track is on par with those, maybe a bit more detailed and fuller.
  18. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
    The SE in R1 won't be in DTS. WB isn't doing DTS releases in R1 any more.
    IMHO It's pretty pointless to compare an LD track to a DVD. I have never heard an LD track that was worse than a DVD. [​IMG]
    You'd be better off comparing this with the DD track on the current DVD which is, again IMHO, worse than this DTS track.
  19. Peter Svensson
    Peter Svensson Second Unit
    Nov 25, 2003
    404
  20. Moz
    Moz Agent
    May 19, 2004
    32
    Hi guys,
    My point is that the LD track (dolby 5.1) is a bit better than the DVD R2 track (DTS) witch is better than the DVD tracks (dolby 5.1) of any Regions [​IMG]
    CraigL... it seems important to me to notice that some LD tracks (bought years ago !) sound better than todays reissues !!!
