Heat bad for Sub?
Discussion in 'Archived Threads 2001-2004' started by Evan H, Nov 1, 2001.
  1. Evan H
    Evan H Stunt Coordinator
    Apr 10, 2000
    95
    My subwoofer is currently sitting directly above a heating duct for the forced hot air heating system in my house. Unfortunately due to the layout of the room, there is no way i can move it anywhere else. is the heat bad for the sub... is there anything i can do to protect it if it is?
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,241
    20
    1,610
    Is it a powered sub? I'd just keep an eye out to make sure the amp(if it is powered)wasn't overheating at all. I don't see any major issues though...
    TV
  3. Evan H
    Apr 10, 2000
    95
    Thanks for the reply Tom, It is a powered sub (B&W ASW 1000). Ok, so the heat's not bad for the speaker in the sub, just make sure the amp doesn't overheat... i can do that. Thanks again [​IMG]
  4. Tom Vodhanel
    Sep 4, 1998
    2,241
    20
    1,610
    Well, you don't want hot dry air constantly blowing across the driver either [​IMG]
    It might be a good idea to talk to BW about it and see what they think concerning stuff like the surrounds on the driver. There's probably little chance of anything worth worrying about, but they would know for sure.
    TV
  5. Evan H
    Apr 10, 2000
    95
