headphone level v. line level outpout
Discussion in 'Computers' started by Oren, Aug 4, 2003.
  1. Oren
    Oren Stunt Coordinator
    Aug 10, 1999
    178
    If I play an MP3 from my laptop to my receiver using the headphone output jack on the laptop, it sounds really bad. Muffled, muted, flat. If I burn the same MP3 to a cd and play it using the receiver/cd player, it sounds fine. What gives?
    Is the headphone output jack the wrong one to use for such things? Does connecting components like this require a line level connection?
    Thanks...
  2. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    33
    Pittsfield, MA
    Jay
    A headphone jack is meant for non-amplified sound devices, say...headphones or speakers whereas a line-out is a constant voltage signal that is meant to be amplified by an external source, say your receiver. So naturally, you should get better sound by using the line-level output when you send audio from your laptop to a receiver.
    [​IMG]
    Jay
  3. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    as stated the headphone jack typically has a pre-amp for non-amplified speakers. your best bet is to reduce the volume levels on the laptop and crank the volume up on the reciever.
