Head up DIYers!! Carbide tipped router bits for $5.00 each at . . .
Discussion in 'Archived Threads 2001-2004' started by Jeffrey Noel, Sep 4, 2002.
  1. Jeffrey Noel
    Jeffrey Noel Screenwriter
    Sep 11, 2001
    1,533
    www.toolking.com and they have free shipping. But you do have to pay a handling fee. Talk about a great deal!!
    EDIT: Here's the direct link: Dewalt router bits
    Mods: I put this Bargain alert here because I thought it would be most appreciated by the DIYers of HTF.
  2. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Jeffrey, nice catch! Great prices on some basic bits.
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,751
    482
    9,110
    Of the bits on sale, which ones would work best for laminate trimming, and which one for veneer trimming?
  4. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Pat,
    The 3/8" flush trim bit (DW6431) might be the best, but I've found that I much prefer using a sprial downcut flush trim bit for trimming veneer (and they ain't cheap!). It gives a much cleaner edge. I think laminate trimming would be less critical but that's just as guess as I've never used it.
    Brian
  5. Rob Lloyd
    Rob Lloyd Stunt Coordinator
    Mar 22, 2001
    234
    I used a 2 flute laminate bit without any problems on Laminate and also with veneer but I'll have to try the downcut ones on the veneer. I have found that a faster pass on the paper backed veneer works better than a slower pass. Seems to be less paper goo sticking on the bit that way.
    Does this mean that Pat might might be dressing up his goods?
  6. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    No roundover bits? I need a 1/4" and 1/2".
  7. Brian Bunge
    Sep 11, 2000
    3,716
    Rob,
    It will be a cold day in hell when Pat finally covers up his "nekkidness"! [​IMG]
    Brian "Soon to be Unemployeed" Bunge
  8. Jon Torres
    Jon Torres Second Unit
    Dec 30, 2001
    288
    Which one of these bits would be best to cut out speaker holes and recesses? I'm thinking the "DeWalt 1/4" Solid Carbide-Tipped Straight". Would that work?
  9. Patrick Sun
    Jun 30, 1999
    38,751
    482
    9,110
    Well, the weather was getting colder (until it decided to get into the 90's today)...
    Jon, a spiral upcut carbide tipped bit is what you want for that particular application.
  10. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    I got 10 comin'......thanks.
    Pete
  11. Jeffrey Noel
    Sep 11, 2001
    1,533
    Glad the link was useful. I bought a couple myself! [​IMG]
  12. Clay Autery
    Clay Autery Stunt Coordinator
    Oct 23, 2000
    158
    Brian and Patrick...
    Where do y'all buy your spiral router bits? I'm going to be doing a lot of mortice/cutouts and some veneer work too... I've not been very successful finding a great selection of bits...
  13. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    i would not use any of them bits on real wood they will check the crap out of it. the bits i use are at least 20 and up usaly 20-35 my frend dues alot of wood working and has showed me the differance between the good and the cheap. i will use on mdfb the cheap bits so you dont wreck my good ones
  14. Pete Mazz
    May 17, 2000
    761
  15. Clay Autery
    Oct 23, 2000
    158
    Great!!! Thanks Pete! [​IMG]
  16. Zac_F
    Zac_F Agent
    Feb 12, 2002
    36
    I put some router bits into my router and it kept screwing my network up... [​IMG]
