HDTV w/ Analog Signal: Bad Picture?
Discussion in 'Archived Threads 2001-2004' started by CraigD, Aug 3, 2002.
  1. CraigD
    CraigD Auditioning
    Aug 3, 2002
    3
    I recently bought a 27 inch HDTV (Samsung TXM2796HF). I am mostly wathcing regular cable on it. In a case like this would a non HDTV of the same size look better?
    I ask because to me the picture looks bad. It is sort of blocky/pixelated especially in areas of solid colors. Kind of look looking at a picture on a computer monitor if you have it set on a low number of colors.
    II read some stuff about HDTVs showing the problems in bad cable signals, but it looks pretty much the same when I am watching a DVD from a non progressive scan player(composite hookup).
    So am I nuts thinking it looks bad? The salesman told me it should look better than a regular TV even on analog signals because of the line doubler?
    The reason I ask is because I am thinking of returning the set and getting a flatscreen analog of the same size. Extra cost isn't a consideration since I bought this TV on an open box discount for only $450. So would I be better off with a 27 inch analog for the same price?
  2. CraigD
    CraigD Auditioning
    Aug 3, 2002
    3
    Oops, meant component hookup for the DVD.
  3. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    Sounds like the set has problems. Yeah, you should get a better picture. Maybe we've discovered why it's an open box item.
    At that size, that price range, I'd stick with a really good analog set.
    Jan
