hdtv via directv wiring
Discussion in 'Playback Devices' started by JoanPablo_T, Sep 21, 2003.
  1. JoanPablo_T
    JoanPablo_T Stunt Coordinator
    Mar 21, 2001
    173
    I did a quick search but was unable to locate the info I'm looking for. I recently picked up a HD dish for directv. Alignment is not a problem, I pulled the info off of Keohi.com and Directv.com. My question is though: do all the wires connect to a multiswitch? or how exactlty do the wires run. It would have all 3 lnb's for the 101/110/119 sats. Thanks guys!
    JP
  2. JoanPablo_T
    Mar 21, 2001
    173
    well, I just figured it out. I had thought the LNB's had a total of 5 outputs. 2 on 2 lnb's and 1 on the third. Turns out only one has 2 outputs, and the other two have 1. For a total of 4. Which then go to the multiswitch as normal!
    So feel freee to close this post. [​IMG]
    JP
  3. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,303
    59
    9,110
    Mississippi
    You are correct in that multi-sat dishes have four outputs but the newer models have a multi-switch built into them already. You would only need another switch if you need more than four outputs and you will need to get a cascadable switch. With a regular switch you will not get any signals from the 110 and 119 satellites.
    -Robert
