HDTV tuner question
Discussion in 'Archived Threads 2001-2004' started by steve*c, Jul 5, 2001.
  1. steve*c
    steve*c Auditioning
    Feb 15, 2001
    7
    If you purchase one of the HDTVs that have built in HDTV tuners what are your options for reception of satellite HDTV programming. Do you need to buy one of the newer set top boxes that have their own HDTV tuners or can you use a conventional set top box and use the HDTV tuner in the television?
  2. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    The HDTV's with built in HD tuners are also direct tv satellite tuners so you would pretty much be limited to direct tv. You would not need another HD tuner unless you wanted to go with Dish Network for HD satellite
