jongYoo
- Apr 11, 2005
I bought plasma display, so I want a HD Tuner to take my analog cable signal to DVI/HDMI until I get digital cable. But I also want to knock out two birds with one stone and go with a tuner/dvd combo. The only one I really like is the LG LST-3510a. My display supports DVI with HDCP and so does the 3510a. I do not know too much about this HDCP piracy prevention but basically, I was wondering if this video format would burned DVD movies. And if it does not, then does it also not support regular family movies burned onto a DVD?
p.s. Does anyone know of any other tuner/DVD combo other than the samsung and Bravo? If you are currently using one please give me your opinions on it.
Thanks alot
-jong
Thanks alot
-jong
