HDTV Sound Levels
Discussion in 'TV Shows' started by Mark_B, Feb 8, 2006.
  1. Mark_B
    Mark_B Second Unit
    Dec 22, 1999
    300
    5
    Indianapolis
    Mark
    After reading the Super Bowl thread I thought I would ask how folks handle the HDTV sound levels. I'm a HDTV noob and just don't understand the difference in volume that occurs, especially between the broadcast show and commercials. You'll be watching a show and you adjust the volume to a comfortable level and then BAM, a commercial blows you out of your seat. This sometimes happens even during a show. A good example is King of Queens. The show starts and everything is fine. They cut to the opening theme and it blows you away. It continues thruout the show everytime they play the scene transition music. I have similiar problems with Yes Dear. The difference between the show and commercials is the worst. I have taken to just muting during commercials, but it is a pain. I thought there was some rule against this. I have no problem with analog, just the digital broadcast. All my HDTV is OTA.
    One other question, why aren't the reality shows shown in HD. Survivor and Amazing Race would be awesome in HD and 5.1 sound.
  2. mylan
    mylan Screenwriter
    Jan 6, 2005
    1,689
    I have the same problem with every show I watch in HD. Its the same old thing since commercials began airing, make them loud and you'll notice. Now we just get it loud AND in 5.1.
    I thought Survivor was supposed to be in HD this season too but it is still in SD on my HDTV. I would imagine getting HD cameras and equipment into remote locations would be the problem, heck ABC was worried about inclimate weather and the distance cables would be ran during the supebowl.
  3. Charlie Campisi
    Charlie Campisi Screenwriter
    Aug 20, 2004
    1,620
    43
    My workaround is to watch everything on tivo and skip the commercials. No help I know.
    Re reality shows in HD, CBS can't even manage to do more than 3 nfl games a week in HD. I don't expect they'd get their act together for a remote island location. Too many cameras.
  4. TravisR
    TravisR Studio Mogul
    Nov 15, 2004
    27,768
    4,531
    I always make sure to have my remote's mute button ready when a show goes to commercial. [​IMG]
  5. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,719
    463
    What's worse is when you channel surf the ATSC/HDTV channels, and the variation in audio levels go from quiet to bombastic with no rhyme or reason for the wide disparity in audio broadcasting levels.
  6. Diallo B
    Diallo B Screenwriter
    Dec 18, 2002
    1,076
    our problem as htf'ers is that we do not compress the sound in our systems. so we get the signal how it was actually processed instead of compressing it into a certain spectrum.
    i prefer not to compress my sound so that i can hear a whisper as a whisper and an explosion as an explosion.
    but that comes with a cost, as the sound techs that provide our service are either forced to pump up signals for no good reason or are just jacking up the signal....
    like others have said, i skip commercials with my dvr or mute them if i am watching live.
  7. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    No, that's not it. Dolby Digital has Dialog Normalization. If it is set correctly, this should not be a problem. (Come to think of it, I'm not sure the decoder I use honors it....) For whatever reason, my CBS -- dialog, everything -- is much louder than ABC, for example.
  8. Diallo B
    Dec 18, 2002
    1,076
    ken,
    i think we are talking about two different things.
    what is dialog normalization?
  9. Mark_B
    Mark_B Second Unit
    Dec 22, 1999
    300
    5
    Indianapolis
    Mark
    From what I have read elswhere, dialog normalization is a bit set in the dolby stream that is supposed to set voice levels all at the same level. It tells your decoder here is the level of normal voice and everything else is scaled from there. Someone correct me if I'm wrong. This would solve the commercial problem, but not the volume differences in an actual show. If the director or whatever wants the music or sound effects blasting, I guess it will have to be. I have a hard time expalining stuff like this to the wife. She thinks it's the new TV.
  10. Tino
    Tino Lead Actor
    Apr 19, 1999
    8,864
    2,178
    Metro NYC
    Valentino
    Survivor has been broadcast in 5.1
  11. Hayes Preston
    Hayes Preston Stunt Coordinator
    Mar 15, 1999
    183
    I don't want to hijack this thread, but since it was already brought up; both Jeff Probst and Mark Burnett have gone on record that they will not do suvivor in HD, the cameras are to large and heavy. However, it doesn't look too bad in SD, and the sound is good.
  12. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Me too.
    HDTV commercials are much worse than even normal TV commercials as far as volume is concerned. You have to mute them.
    The funny thing is anybody remember what the original purpose behind Dolby's "Dialog Normalization" was, and why it was included in the DD spec?[​IMG]
  13. Mike Williams
    Mike Williams Screenwriter
    Mar 3, 2003
    1,020
    Since the show is taped on DV cameras, couldn't Survivor or The Amazing Race simply bump up to HD DV cameras? They're still lightweight and while they're not as good as full blown, high end, studio high definition cameras, they're not using high end Beta SP cameras anyway, they're using DV. I think they could use HD DV cameras and still be mobile but still give a widescreen picture with more resolution than what we're getting now.
