HDTV Receivers
Discussion in 'Playback Devices' started by HomerG, Jan 16, 2004.
  1. HomerG
    HomerG Auditioning
    Aug 5, 2002
    9
    I'm starting research on the HDTV that I want to buy and apart from the TV, there is now the receiving and decoding of the over the air HD signal itself. Just looking at Circuit City, they sell two of them, a motorola MOT HDT100 at $299, and a Samsung SAM SIRT351 at $399. I'm sure there are others.
    What makes a "good" receiver? Any ideas as to why it seems so expensive (maybe it's just me)? And are there HDTVs that come with a "good" tuner already built in?
  2. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    HomerG,
    Have you decided on the way you are going to receive HD signals (Cable/Satellite/Over the air)? If you are looking at Cable or Sat, the box is included and you do not need another box unless you have satellite and want your locals over the air (OTA). If you need OTA reception, you do need to buy a box.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    I was at a few different stores including a CC the other day, and most stores right now, have open box HDTV tuners for around $200. I bought a Zenith HDV-420 before xmas for around $200 as well.
    They all have very similar specs and features, I don't know that there is much difference at all performance wise. I am happy with mine.
  4. Kevin G.
    Kevin G. Second Unit
    Sep 30, 2003
    403
    I was researching my HDTV monitor and looked into a tuner @ my local Radio Shack and theirs were 300.00, and 500.00
    'Course all their stuff is kinda high priced
  5. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    Am I to understand that if u have satellite and have subscribed to local channels, u will not be getting HD broadcast from said network locals?
  6. Nathan_R
    Nathan_R Supporting Actor
    Dec 4, 2000
    717
    Eric,
    You will not receive your locals in HD via satellite. You will need an antenna to pick up any local digital station.
    The only exception is the national CBS-HD feed via Dish Network, which the majority of people cannot receive (it's a matter of qualifying for the station).
    [​IMG]
  7. Todd Henry
    Todd Henry Second Unit
    Feb 4, 2002
    324
    I am getting my DirecTV receiver probably on Tuesday, but the Installer is not arriving until Saturday. If I have an antenna can I get the OTA channels before the installation?
    Todd
  8. Iver
    Iver Second Unit
    Sep 23, 2002
    324
    You can if:
    1) your antenna is connected to an H/DTV OTA receiver, also known as a set-top box or STB, and this is in turn connected to an HD-ready display or;
    2) your antenna is connected to an "integrated" H/DTV (a set with HD rez and an in-built H/DTV tuner).
    Even after the satellite install, you're still free to tune your local H/DTV OTA channels (as long as you have the above gear).
  9. Todd Henry
    Feb 4, 2002
    324
    Iver,
    Thanks. I will be getting the receiver during the week so I will be able to use it as soon as possible. That is great news.
    Todd
  10. Hank
    Hank Guest
    Just picked up the Motorola HDT100 and a RCA 1250 indoor antenna to pick up my local HD channels. The HDT100 works great and is a great value. The only features it lacks is DVI (my HDTV doesn't have DVI) and a coax digital out (optical only). It was very easy to set up. I can't wait to watch the Superbowl on CBS.
  11. HomerG
    HomerG Auditioning
    Aug 5, 2002
    9
    In reply to Jeff Gatie, I am looking for OTA, since I currently live in a condominium complex, and I can't get Satellite installed, and I don't want to pay for Cable right now.
    In reply to Hank, do other receivers come with the option for DVI?
  12. John S
    John S Producer
    Nov 4, 2003
    5,460
    Some of them do have DVI indeed....
    Mine dose snto have DVI either, and neither does myy TV...
    The 1080i looks awesome, and the real DD sound is great too.
    Bring on that Super Bowl in HD!!!!!
    PS: Tonight for the first time in history, the State Of The Union Address is sposed to be in HD....
  13. Matthew Todd
    Matthew Todd Second Unit
    Jan 3, 2000
    338
    The Samsung 351 has DVI. Last Saturday I got an open box special on this for $300. I'm most interested in its VGA (RGB) output though. My projector has RGBHV in, not DVI. I'm looking forward to having the electrician come and install an attic antenna (new house, no antenna at all yet) so I can try this guy out.
  14. DuWayne
    DuWayne Stunt Coordinator
    Sep 8, 2003
    160
    DirecTV WILL start broadcasting HDTV Local over SAT, starting with the SuperBowl.
    All CBS-HD content and 2 weeks later all FOX-HD content.
    You can read about it on their website here...
  15. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Only a very small number of DirecTV customers will have access to the CBS-HD and Fox-ED feeds, only where the local affiliate is owned-and-operated by the network. The majority will be denied access and must receive it locally with an antenna.
