HDTV Projector or Widescreen ??
Discussion in 'Archived Threads 2001-2004' started by Chris Bates, Nov 25, 2002.
  1. Chris Bates
    Chris Bates Stunt Coordinator
    Nov 28, 2001
    74
    If given the choice, would you choose a HDTV projector and screen, or a HDTV widescreen tv? Which model, and why?
    I really need some opinions on this one....Thanks
  2. Chris Rosene
    Chris Rosene Second Unit
    Nov 3, 1999
    336
    If your application can support it (light controlled room, proper throw distance, etc) there is no question . . CRT. By FAR the best bang for the buck. End of story.
  3. Ron Boster
    Ron Boster Screenwriter
    Jan 10, 1999
    1,145
    Chris:
    In my opinion, if you have the space and light control....FP is the route to go. Then you must decide between CRT vs digital (LCD/DLP etc). I would run a search using front projector, newbie etc and read up on FP's this should give you a basic knowledge and then you can follow up with specific questions.
    Bottomline for me: a FP with a large screen (106" for me) gives me the true feeling of being in a home theater/screening room. Befoer that I was a RPTV owner for the last 15 years.
    Good Luck
    Ron
  4. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Here is a little reading you can do to start...
    Front Projection
    How do I select one for my my needs?
    First things first, let me first explain what front projection is. Basically what I am talking about is using a projector to project a video image onto a screen that is in front of the viewer. This is the same method used in movie theatres today with the screen at the front of the room/theatre and the video projector located towards the back of the room.
    With the prices of front projection coming down to reasonable levels, and with HDef becoming more accepted by the masses, more and more people are finding that a front projection system is within reach and an acceptable upgrade for their home theatres. There are a lot of questions that must be answered in order to know which type of projector is best suited for your home theatre.
    First of all, there are various types of projectors. I will not discuss the differences in this article in great depth but only cover the most important issues. The major types of projector consist of CRT, LCD, DLP, DILA and LCOS projectors, with the first 3 being the most common for home use. Each has its advantages and disadvantages so these must be factored into the final decision process.
    The MAJOR advantages/disadvantages between projector types
    1- CRT - The earliest front projectors were CRT (Cathode Ray Tube). Traditionally they were expensive, heavy, and difficult to set up but delivered top notch picture quality. Many are not as bright as the digital projectors of today so they will need a room that has absolute control of ambient light to prevent the picture from being "washed out". The biggest advantage though is their ability to produce very good "blacks". These units need to be set up at one point and not moved from that point. Once set up, convergence will also have to be done for best results. Many can be found used at reasonable prices.
    2- LCD - These digital projectors have become more and more popular today as they offer a lot of flexibility and ease of use. Prices vary from cheap to around the mid-point of the range of prices. Many offer zoom lenses that allow a range in their location because the picture size can be zoomed to the size of the screen, as well as keystone correction to correct for projector height in relation to the screen. Some of the things to watch out for are possible screen door effect where the pixels structure can be seen from a few feet away, and black level being more dark grey than black. These projectors can offer colours that are "punchy" when compared to other digital projectors like DLP. This is not necessarily true for all LCD and all DLP projectors though. Other considerations are bulb life and the "dead pixel" issue. Once a bulb has reached end of life, it will need to be replaced and could cost a couple of hundred dollars to do so. Sometimes an LCD projector can have what is called a dead pixel that does not change colour like it's neighbouring pixels do. This may hardly be visible unless you look very closely at the screen. You may observe a pixel that stays green all the time for example. The problem arises if there are a group of dead pixels together in one area which may cause it to be visible from the main viewing area.
    3- DLP - These digital projectors differ from LCD in the way they create an image but basically with DLP (Digital Light Processing), pixels are also projected at the screen. They offer many of the same features as LCD projectors with regards to flexibility and also some of the same concerns like bulb life. Screen door is less of an effect than LCD, typically, but not always. Contrast ratios can often be higher than with LCD, creating better blacks, but light output can also tend to be lower than with LCD. Often, the colours are less saturated and more washed out than with their LCD cousins. Other considerations are the "rainbow effect" that can be visible on many DLP projectors, typically those with slower colour wheels and some people have claimed getting headaches while viewing movies on some DLP units. The following is an interesting article from Texas Instruments on the concepts of DLP projectors and how a single chip revolutionized these projectors. dlp.com "DLP technology" (click "Launch our demo" under "See How It Works" on the upper right)
    4- LCOS & DILA - These are other types of digital projectors. There are presently not many LCOS or DILA projectors on the market for home use and they are also a lot more expensive.
    OK, so how do I select one for my my needs?
    There are various considerations to determine which type and model of projector is right for your setup. A useful search function can be found at Projector Central, that allows you to search on price, brightness, resolution, projector type, etc to help with the decision making process as well. Let me list the considerations and flesh out each one...
    Budget - This is perhaps the most immediate limiting factor. Obviously at the time I write this, the pricing will differ as time goes by which makes it hard for me to consider specific models. When considering budget however, one must factor in not only the price of the projector, but the price of a matching screen (a do-it-yourself screen is also an option), a mount for installing the projector to the ceiling, and cabling to the projector. Prices will vary greatly on each type of projector as well costing anywhere from a few hundred dollars for a used projector, to a couple thousand dollars for a new entry level projector, to a few thousand for a CRT, mid-range LCD, mid-range DLP, to ten thousand dollars and up for higher end LCD, DLP, CRT and LCOS projectors. In some cases, an outboard line doubler (or scaler) may also be needed. In effect, this increases the resolution of the picture being displayed so that the projector's maximum resolution can be utilized. A good projector will have decent internal scaling but if not, an external one can be used but this would need to be added to the budget as well.
    The screen & projector. 16x9 vs 4x3 - In order to determine which native aspect ratio (4x3 or 16x9) is better for your setup, you first need to know what source material you will be viewing more of, and where to make the necessary trade-offs. Many of the movies available on DVD (not all) for example are in widescreen format as opposed to 4x3 format. Most of the material broadcast on local cable TV is in a 4x3 format. HDef broadcasts are mostly in widescreen as well. If most of your viewing will be widescreen material then the native 16x9 resolution of a projector will serve you well. For instance, a movie like Toy Story which has a 1.78:1 aspect ratio will fill the entire 16x9 screen. Viewing the same movie on a 4x3 projector and screen will result in black bars on the top and bottom of the screen, and less of the resolution of the projector devoted to the movie. The flip side however comes when viewing 4x3 material on a native 16x9 projector and screen. In this case, you will get black bars to the left and right of the image. A third consideration to consider is most 16x9 material is of a higher quality than 4x3 material so choosing a 4x3 screen to view both widescreen and full frame on it will yield a widescreen movie with black bars on the top and bottom, as well as a blown up (large) 4x3 image that shows all of the defects of the 4x3 material. A complete article can be found at Projector Central for more reading... 4:3 vs. 16:9 - how to select the right format
    HT room dimensions, screen size, and projector "throw" - Room dimensions must be taken into account as well. The length of the room from the front to the back can come into play. The first thing that is important regarding screen size is that it is not recommended sitting closer than 1.5 times the screen width otherwise the image becomes too large to watch comfortably. Once the length of the room is known, you need to determine the screensize you would like to have, and if it will "fit" into the room. For instance, a 16x9 92" screen is 45" high and 80" wide so seating should be no closer than 1.5 x 80 = 120" or 10ft. You also need to determine if the particular projector can create an image of that size withing the boundaries (length) of that room and still have enough space behind for cooling purposes. This is also know as the projector's throw. Most rooms will have a high enough ceiling to accomodate the projector and screen but a very low ceiling may in fact rule out a possible front projection setup.
    Source material & resolution - Today's DVD resolution is 640x480. Some Hdef programming is broadcast at 720 lines progressively, or 720p, while others are broadcast at 1080 lines interlaced, or 1080i. DVHS's resolution is also 1080i and future formats like HD-DVD may also be this resolution. The resolution of the formats you watch, and the ones you would like to watch is another consideration. Projectors come in various 4x3 and 16x9 resolutions. I will list them with their resolutions...
    . VGA = 640 x 480
    . WVGA = 858 x 484
    . SVGA = 800 x 600
    . XGA = 1024 x 768
    . WXGA = 1366 x 768 or 1280 x 720
    . SXGA = 1280 x 1024
    . WSXGA = 1365 x 1024
    . UXGA = 1600 x 1200
    . QXGA = 2048 x 1536
    Obviously, the more pixels displayed, the less visible and smaller the pixels will be and the better the picture quality, all else being equal. Price tends to increase with resolution as well. Many projectors will "down-convert" a higher resolution to fit their native resolution but a projector that is capable of a higher resolution should be considered before one that has a lower resolution, all else being equal of course.
    Your HT room's ambient light, projector brightness & screen gain - Some of us are "fortunate" to have a room that can be totally light controlled (made pitch black even during the daytime), while others of us have room with lots of ambient light. Being able to control the amount of light in a room is very important, no matter what type of projector is used but a projector with higher brightness will be able to handle a room with ambient light better than a projector with low brightness. Many lower end projectors and some of the CRT units can have a brightness of 300 to 600 ansi-lumens. Essentially, these should be placed in a room that can be made totally dark. The better LCD and DLP projectors can be as bright as 1000 a.l. and some can be upwards of 1500-2000 a.l. Ambient light will wash out the colours and the blacks as well resulting in no shadow detail and rendering the picture un-watchable. Once you select a projector then a suitable screen must be selected to match it with an appropriate amount of gain. The higher the gain of the screen, the brighter the image on the screen and the more resistant the image is to a room's ambient light. A reputable home theatre store can usually recommend a suitable screen for a projector you choose but it helps to know the dynamics of the room, particularly how much ambient light it may have.
    Contrast ratio - What is contrast ratio? Contrast ratio is the range between the lightest and darkest light that a projector can produce. The higher the contrast ratio, the better a projector is capable of producing blacks on the image. This is where the better CRT projectors and the higher end DLP units shine. Make no mistake though, LCD technology with the higher end units is on par should not be ignored either. In any case, those with a lower on/off contrast ratio vary anywhere between 250 - 600 a.l. while some are 600 - 1000 a.l. or higher.
    Inputs/connections - At a minimum, a projector should have composite video, s-video, and component video inputs. Some projectors will accept progressively scanned signals so this is important if either using a progressive scan DVD player of a HDef signal. Other connections include a 12V trigger for a motorized screen and a DVI port. A DVI port (digital video interface), if a projector is equipped with it, allows an outboard scaler or home theatre PC (HTPC) to be used to scale an image to the highest resolution that a particular projector can accept, and can result in amazing images. The most common type of DVI connection is the 15- pin analog DB15 VGA style of connector that computer monitors use. Some others have DVI-D which is a digital 24-pin variant. For more information on DVI, read this article from Dell.com...
    http://www.dell.com/us/en/arm/topics...s_2000-dvi.htm.
    Other features/considerations - There are lots of different features that may prove to be of use to a potential buyer. Some of those include manual/power focus, manual/power zoom, keystone correction, lens shift, inboard speakers and more. The last consideration I will mention is bulb life, something that must be kept in mind with digital projectors. The higher the bulb life the less frequently it will have to be changed. As this is an expense, a higher bulb life will be advantageous. Typically, bulb life varies between 1000-2000 hours. Some projectors offer an "econo" mode that lenghtens the life of the bulb by slightly reducing the light output.
    Conclusion - Once you consider all of the above criteria, a list of hundreds of potential projectors can get narrowed down to a few, or even one that is the best in your situation. There are many online websites that contain specifications that help with the decision making process. As well, it is always best to demo a projector for oneself at a reputable local home theatre store rather than buy sight unseen.
  5. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    Regarding your question, I would definitely lean toward an HD Projector unless you watch a lot of TV on it and assuming your room is suitable for a FPTV setup as per my post above.
  6. Chris Bates
    Nov 28, 2001
    74
    Thanks for the replies guys, keep em coming. It seems like I have spent my life in the pursuit of something bigger or better than what I have. My first HT was a pro logic system w/ a 27" tv, huge towers, and what was then top of the line equipment. I went from the 27" to a 36", then to a 43" table top, and now I have a 64" bigscreen. I have recently sold off all my equipment with the exception of the big screen, in order to upgrade. It is going slower than I would like, but that's to be expected. I am in the process of building a house, and I have made provisions for a dedicated HT room. The cost of building the room now, is considerably less than adding it later, so I figured "why not". I have decided after much debate to sell my bigscreen and either get a large hdtv widescreen tv, or a front projector.
    The Idea of a 100"+ screen gives me goosebumps, but will it have the same picture quality as an HDTV widescreen? What brand and model of projector would you guys recommend. I want one that is capable of a 16:9 aspect ratio. Keep in mind that I am not a wealthy man so the really high end projectors are way out of my league. Im looking for more of a "Bang for the buck" kind of projector. Let me know what you guys think, I could really use the advice.
  7. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    As long as you set it up right, it will indeed have an equal or better image from the seating position than a RPTV would.
    For starters, check out....
    WXGA projectors - Projector Central
    ... but do yourself a favour and do some demos of your own in reputable stores.
  8. Ron Boster
    Jan 10, 1999
    1,145
    Chris:
    Read all the material you can get your hands on....
    Locally demo a crt, DLP and LCD....
    Then decide if CRT vs digital, if digital then which type?
    DPL (some complain of headaches and seeing "rainbows")
    LCD: Depending on quality of projector and distance from screen-some notice a "screendoor effect"
    Only after viewing the digitals can you really answer the above questions.
    What is your budget? My idea of a "budget" projector maybe different than yours.
    Do the research, then come back after you have narrowed your search to what type of projector and your budget...I'm sure everyone will have many suggestions/favorites for you to review. To make suggestions prior to you doing your research would be a shotgun approach and may in the end result in you being unhappy with your projector.
    Good Luck
    Ron
  9. Chris Bates
    Nov 28, 2001
    74
    Well, im looking at around $6,000 for a prejector. I would like to be able to get a screen out of that too if I could. Like I said, Im not a rich man, but I have always been able to scape up enough money for decent equipment. I wish I could afford one of those $50K-$100K systems that some of you guys have, but I cant. Since the screen is the center of attention, and while I can afford it, I want to get the best projector and screen system that I can get for the money. The audio equipment can be upgraded a lot easier that the video, so I'll most likely start off simple there, and upgrade as I go. Probably starting with the speakers, then the receiver, and so on, and so forth. I have an extensive background in speaker design and construction, as well as custom fabrication and motorization, so I will be doing a lot of the work myself, and will probably end up saving myself several thousand dollars. This will allow me to direct the majority of the budget to the equipment itself. I just want to make sure that I do it right from the start. If its one thing that I have learned in nearly twelve years of design and fabrication, its that it costs a hell of a lot less to do it right the first time around, as it does to go back and correct a mistake. Words to live by....
  10. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    Like Ron said. Do some indepth demos the next xhance you get.
    Regarding screens, you can do anything from a DIY approach by obtaining the screen material (which some members here have done) to getting a full blown Stewart Firehawk (a great screen for digital LCD, DLP projectors), and in between. First though, you need to determine which projector you are getting first then match it up with the screen.
  11. Michael Mathius
    Michael Mathius Supporting Actor
    Nov 12, 2000
    915
    110
    I recently ordered the Sony HS10 which should be here any day now according to my dealer [​IMG] I've been lucky to audition a number of projectors during the past few weeks. Last night my wife brought home a Proxima 9270 which is a native 4x3 but also nicely displays 1080i. The quality of the hd feed projecting unto an eight foot wall was amazing. I watch Ice Age,Men in Black and the Dallas Maverick Cheerleaders on HDNet [​IMG] [​IMG] [​IMG]
    Since I will only be watching dvds and hd on the projector I went with a native 16x9
