Skip Hammerman
- Nov 30, 2001
Is there a difference and what are the pros and cons.
Thank you for your comments!
unless one or the other were adding some additional compression.If I am not mistaken, cable does. At least that is what I thought I had read somewhere. I think that is where QAM comes into play?
DirecTV uses MPEG for their stuff, just like the HD Spec says, but that does not mean they are compressing it at even a higher rate.
