Westly T
- Oct 5, 1999
I live in Oceanside, California. This city is located in San Diego North County. I find I can get some OTA HD channels. Before buying my equipment I tried to find out if anyone else knew if I could get reception, but came up empty, so I thought I'd add a post in case others in my area also want to know.
I just got a JVC Dish Network 6000 with the 8VSB OTA HD module and did some testing to see what local HD channels I could get in my far from ideal location. I can get KGTV-DT (25) and KFMB-DT (55) with a signal strength of 60 - 70% but found reception best when turned slightly to the left of the highest signal strength, about 62-64%. I'm using a large YAGI (Radio Shack 15-2162 now discontinued, I got it for $4.95 new in a RS store!) with 100" boom and 34 Elements sitting on a 10' pole on the ground. I live in the San Luis Rey River canyon near HW 76 and College. There is a 2-story house across the street directly in the path to the 168-degree transmitters, not to mention the hills and mountains. I couldn't get any other channels, but there are huge trees in the path to the LA stations, and other objects in the way to others. I used a high quality RG6 cable approximately 35' in length with a Channel Master 300 Ohm to 75 Ohm transformer. I've also tried it in an upstairs bedroom pointing through a window and only lost about 2% of the signal strength.
This weekend I'll have a Channel Master Model 7775 UHF high quality preamp and plan to try an attic or roof location to see if I can get more stations. I'll post again when I have more information. I want to keep my antenna out of sight as my HOA forbids antennas, even though federal law over-rides this rule, because I don't want to make enemies unnecessarily. Currently there zero antenna's visible in my neighborhood and only a few DSS dishes (my DSS dishes are also hidden).
Source of information on local stations: http://www.antennaweb.org/aw/address.asp
Read the FCC info allowing antenna’s here: Link Removed
