HDTV install
Discussion in 'Archived Threads 2001-2004' started by GaryCT, Mar 7, 2001.
  1. GaryCT
    GaryCT Auditioning
    Jul 5, 2000
    8
    What is the best antenna for getting HDTV and local stations? I assume it is a UHF/VHF antenna that will do HDTV as well.
    Gary
  2. Bob Dycus
    Bob Dycus Extra
    Aug 12, 2000
    16
    It all depends on how far you are from the transmitter. Most HDTV is in the UHF band. If you are within 30 miles of the transmitter, a simple indoor bowtie antenna will probably get HDTV. The Silver Sensor antenna has gotten good reviews. An antenna that works well for standard TV will also work well for HDTV since they are both just radio waves.
  3. Steve Tannehill
    Steve Tannehill Ambassador
    Jul 6, 1997
    5,547
    215
    DFW
    Steve Tannehill
  4. RoyGBiv
    RoyGBiv Stunt Coordinator
    Apr 10, 2000
    229
    I am 35 miles from the Boston HD transmitting tower and get excellent reception with a simple Radio Shack antenna. It is meant to be used outdoors, but it is mounted in my attic. I don't use an amplifier. I don't remember the model number, but it is the second largest antenna they make. If you don't want rabbit ears over your TV (I sure didn't), an outdoor antenna mounted in the attic should work well. For further distances, you may need one mounted outdoors with an antenna.
    SMK
  5. Timmy
    Timmy Stunt Coordinator
    Sep 22, 1998
    160
    I installed a 32 element TV antenna on a 10' mast on my roof peak. I get 4 HDTV stations from 40 to 45 miles away with signal strengths from 72 to 80 percent (dish 6000 w/8VSB ota tuner).
