HDTV in apartment...possible???
Discussion in 'Archived Threads 2001-2004' started by jeff lam, Jan 21, 2003.
  1. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I'm looking into getting HDTV but it may be a challenge since I live in an apartment. The complex does have an antenna routed to all the units but it doesn't even pick up the SD channels very well at all and I'm assuming the antenna is no good for HD signals anyway. Is there any way I can get good HD from all available OTA channels without a huge antenna?
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,722
    463
    You mainly need a good UHF antenna (since most OTA HDTV is broadcasted on UHF), and good antenna direction towards the broadcasting towers.
  3. Matt Goddard
    Matt Goddard Stunt Coordinator
    Mar 21, 1999
    174
    When I moved into my house I was forced to wait a week for my cable installation so I experimented with an antenna in my basement entertainment room. I couldn't pick up a thing, however. Two weeks ago I bought an OTA HDTV receiver and an antenna with amplifier and I have no problems picking up the two stations broadcasting locally in HDTV. I still can't pick up any of the analog stations, though. I'm just using a $50 Jensen antenna from Best Buy, so I wouldn't be discouraged just because you can't currently pick up analog channels.
  4. ManW_TheUncool
    ManW_TheUncool Producer
    Aug 18, 2001
    5,987
    36
    The BK
    ManW
    You never know until you actually try.
    For starters, you should check this site to get a rough idea what's possible:
    www.antennaweb.org
    _Man_
  5. jeff lam
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I could pick up a receiver and try out the antenna already connected, but my question now is: will sharing the antenna between 12 apartments going to affect anything? (At least that's how I think it's hooked up).
  6. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
    Hi Jeff,
    I live in Oakland, and have a building with 12 units as well. We all share this old rusted antenna that's on the top of the roof. It never picked up regular SD TV too well, but it works perfectly for HDTV.
    I had to go up on the roof and point the UHF antenna toward Mt. Sutro (which you will have to do the same).
    The only HD channel I can't get in NBC, but that's because of their antenna location in the Bay Area. Give it a shot, most likely you will be fine if you can go up on the roof to make some minor positioning adjustments. Also, you could always offer the landlord to purchase a new antenna for the building if you were really out of luck with making adjustments. Once you see HDTV, its hard to go back. Good luck!
  7. Chris S
    Chris S Cinematographer
    Apr 9, 2000
    2,538
    9
    Chris S
    I lived in an apartment about 15 miles away from the main towers in the Dallas/Fort Worth area. With a clean line of sight I was about to get pretty good reception with a regular pair of rabbit ears.
    Chris S.
  8. Daniel Mai
    Daniel Mai Stunt Coordinator
    Oct 2, 2001
    225
    Try the complex antenna, if that doesn't work, try the ever popular Radio Shack double bowtie ($18) and it'll work great.
    Like Patrick said, just a UHF antenna is all you need. Ironically, I bought a Terk amplified indoor antenna from Best Buy for $100, hooked it up and had troubles receiving signals. Then I read about the RS double bowtie, tried that and it works great. It's so small that you can leave on top of your TV to make minor adjustments for better reception. I actually have mine in the attic (fixed location) and it picks up all the local OTA HDTV.
    Good luck and get ready to be stunned by the images!!:b
  9. Jack Briggs
    Jun 3, 1999
    16,738
    129
    You'll be amazed at what's possible for free (after the upfront costs, of course). Good luck, and keep us posted please.
  10. jeff lam
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    Thanks for the help guys! I'll look into it.
    One more question... Will I still need to subscribe to local channels through Directv if I have HDTV locals? Do the HDTV towers send out the SD signal when there isn't an HD program on?
    Also, what's the item # of that popular Radio Shack double bowtie?
  11. Patrick Sun
    Jun 30, 1999
    38,722
    463
    Unfortunately, the RS Double Bowtie antenna is discontinued. It is in the printed catalog (you'll know it when you see it - look in the antenna section), but I don't think it's on the website anymore.
    Many people have lucked out by getting them on clearance (like $5) but most RS stores are sold out of them. You never know unless you call your local RS stores or visit them.
    I had to resort to other online means to get mine (I think I got mine from another HTFer). With the 10dB booster, mine works pretty well.
  12. Dennis Nicholls
    Dennis Nicholls Lead Actor
    Oct 5, 1998
    8,937
    347
    Boise, ID
    Dennis
    Jeff, you probably are hosed. You don't live that far from me (Cambrian Park district) and I found that I needed a big rooftop antenna to get DTV from Sutro Towers. A medium-sized antenna wasn't good enough. Sutro's about 50 miles away in San Francisco.
  13. NatL
    NatL Stunt Coordinator
    Sep 18, 2002
    72
    Am I missing something in all this - it seems that there are OTA-HDTV receivers that cost hundreds. But I don't need one of those - I can just buy a good UHF antenna and I'll get HDTV? (I do have an HDTV-ready TV).
    N
  14. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
    NatL, unless you have an HDTV receiver built into your set, you NEED an external Set Top Box (STB) in order to receive the HD signal.
    Just having a "HDTV-Ready" TV is 1/3 of the process. You then need 2. A Receiver, and 3. An HD Signal from Over The Air Antenna, Cable, or Sattelite.
  15. Joe6pack99
    Joe6pack99 Second Unit
    Mar 6, 2000
    435
    Whats interesting is I just found out Time Warner now has a cable box with a decoder built in...it sends the decoded hd video too the hd ready tv via the component output.All the tv has too do is be able too accept and display hd video.
  16. ManW_TheUncool
    Aug 18, 2001
    5,987
    36
    The BK
    ManW
  17. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
