Mark J Graham
- Sep 3, 2001
I just got my cable company box that has HDTV and want to hook it up.
I picked up Monster 3 component video cables, and realize that both the receiver and the TV have the 5 cable hookup, the 3 component plus the Horizontal and Vertical sync. What cables would you recommend using for these connections? Do I need to go out and spend another $80 on a Monster 3 cable and just use 2 of them, or is there a better option?
Thanks.
Mark Graham
Thanks.
Mark Graham
