HDTV Help (OTA decoder and X1 projector)
Discussion in 'Displays' started by Tim Abbott, Nov 24, 2003.
  1. Tim Abbott
    Tim Abbott Second Unit
    May 10, 1999
    284
    Tim
    I thought HDTV was going to be a snap, but it hasn't exactly turned out that way. Here is what I have:
    -X1 projector
    Description
    -Panasonic OTA reciever
    Description
    I also have a component to VGA breakout cable, which to my understanding should work fine.
    Could someone explain what kind of antenna I need? I had assumed that the one I currently had would be fine, but that may be the problem. I receive the networks (NBC, ABC, CBS) crystal clear with my current antenna. It is old (maybe 20 years) but it works great for analog. Is this where my problem is??
    I know the HDTV decoder works, and I know that the VGA port on my projector works (tested it w/ a laptop). I don't really want to buy a new antenna, but how can you put a price on watching sports in HDTV [​IMG]
    Any advice would be appreciated. Thanks!
    Tim
  2. Hank_P
    Hank_P Second Unit
    Nov 15, 2000
    321
    19
    110
    If you are receiving your broadcast already, you may not need another antenna. I currently have a Radio Shack Double bowtie antenna I purchased for $1.95 on clearance. It receives every channel broadcast in my area. You might check out www.antennaweb.org to see what Digital channels are being broadcast in your area.
  3. Tim Abbott
    May 10, 1999
    284
    Tim
    Hi Hank,
    Thanks for the ideas. I know that there is plenty of HDTV being broadcast in my area, and I know that I receive it. I also *think* that I have an antenna that should be able to pick up HDTV, but I'm not sure. I would rather not go out and pick up a new antenna as it would likely have to be one of the big roof mounted ones.
    Does anyone else know of any problems/quirks I have with my equipment???
    Please help!!
  4. GregAnderson
    GregAnderson Extra
    Feb 9, 2003
    17
    Are any of your analog channels UHF? are anhy of the new digital channels in your area VHF? It is possible that your old antenna is VHF and your new digital channels are UHF. If that is the case, you'll probably have to buy a new antenna. I also use the RS Double Bow Tie. That and the Silver Sensor seem to do a pretty good job. You may not have to get a new roof mount. YMMV.
