HDTV/DirectTV/DVR
Discussion in 'Playback Devices' started by JimmyW, Oct 29, 2003.
  1. JimmyW
    JimmyW Auditioning
    Sep 17, 2003
    Hi,
    I was wondering if any knew it there was a HDTV/DirectTV receiver that also had a DVR? I am a current subscriber to DirectTV and have a HDTV without a HDTV tuner and am looking to fix this oversight. Any comments are appreciated.
    Jimmy
  2. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    There is not. You need two units: a DVR and a DirectTV HD receiver.
    Supposedly there will be a DirecTV HD PVR (tivo, iirc) in 1st qtr 2004. No question that this will happen, it is just a case of when.
    Of approach to solving the problem today is to use a multiswitch, with one line to the HD receiver and two lines to the PVR. On the output side, component (or DVI) connection from the HD receiver to the display and an S-video (or composite) from the PVR to the display.
    Where you have a problem is if you are watching an HD telecast and you want to use the ‘pause’ feature of the PVR. You need to get the PVR on the right channel and after that the catch-up is in SD.
  3. John Sorensen
    John Sorensen Auditioning
    Oct 17, 2002
    11
    Maybe I am off base here but what about this new Zenith HDR230. HD Reciever/HD DVR all in one box? Do an internet search?
    HDTV Broadcast Receiver & High Definition Personal Video Recorder
    Allows Over the Air HDTV Reception
    All Format ATSC Receiver
    Utilizes Zenith's 4th-generation VSB technology for improved terrestrial/cable VSB-DTV reception and noise immunity
    Various Display Options
    Selectable output format allows configuration on different displays in both 4:3 and 16:9 formats
    Display Format Control
    Allows selection of output display formats
    Electronic Program Guide Based on PSIP
    Pause/Playback, Live TV (Time Shift)
    Live and reservation recording, variable speed slow motion, fast-forward, and rewind. Time Shift feature allows the review of a segment that you missed during a view
    User Friendly GUI and Fast Program Screen Tuning
    Enhanced Scaler
    Provides superior picture for different formats
    5.1 Channel Dolby Digital™ Sound
    Provides Dolby Digital audio to create 5.1 channel sound for home theater
    Front LED Display
    Digital Closed Captions
    Fast Program Search for Tuning
    Built-In 80 GB Hard Drive
    Records more than 8 hours of HD content via antenna
    Book Marked Play Bac
  4. Brian Fitterman
    Brian Fitterman Stunt Coordinator
    Mar 26, 2002
    243
    John, close, but he wants DirecTV with DVR functions.
  5. John Sorensen
    Oct 17, 2002
    11
    I have the Zenith HD-520 Sat Reciver that recieves DirectTV signal just fine. Why would this be any different? What am I missing?
  6. Stephen Tu
    Stephen Tu Screenwriter
    Apr 26, 1999
    1,573
    It's different because it's a different model, and not a satellite receiver. I don't understand your point. Just because Zenith makes some models of satellite HD receiver means all their models must be both satellite/OTA? That doesn't compute. Other companies like Panasonic & Samsung have also made OTA-only receivers. Tivo probably has some sort of exclusive contract with DirecTV for PVR services.
    The HDR-230 also has a major drawback of not being able to view previous recordings while recording a new show.
  7. John Sorensen
    Oct 17, 2002
    11
    Oh, i get it now, you have to excuse me as it takes a while for things to sink in. I live where technology is so far behind. We only have one OTA HD signal right now. I have to gt all my info from the internet boards like these so thanks for clearing that up!!
