HDTV antenna
Discussion in 'Archived Threads 2001-2004' started by FredV, Jan 8, 2003.
  1. FredV
    FredV Agent
    Dec 27, 2002
    27
    Anyone have any experience with Channel Master 3010 Stealth antenna? I live in central NJ. If not, any recommendations for OTA HDTV reception?
  2. Christo
    Christo Agent
    Mar 27, 2000
    33
    I'd also like to hear anything on this subject
    What HD Tuner are you using?
  3. FredV
    FredV Agent
    Dec 27, 2002
    27
    I have the Toshiba dst-3000 although it's not hooked up currently.
  4. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    I don’t have any experience with this particular antenna. However, there is no difference between a suitable antenna for analog and digital signals.
    How good (or big) an antenna you need depends on your location and the transmitting antenna’s location. Both distance and things like large buildings in the way (this can create multipath probems). There is also the location of the antenna to be considered. For example, most roof mounts provide a stronger signal than the same antenna mounted in an attic.
  5. Victor de la Uz
    Victor de la Uz Auditioning
    Oct 8, 2001
    3
    I just purchased it recently and haven't had the darned time to install it yet! I'll post back once it's up. I'm planning on splitting the signal to a Zenith 520 STB for HDTV and to a Denon 4802 for FM. I've got it on a Channel Master RC IR rotator. Now, if I could just find the time to FINISH the install...
