Sean Patrick
- Apr 22, 1999
just got an HDTV yesterday (F38310) and was anxious to get my OTA channels going. My tv has an internal receiver so all i needed was an antenna...i live 10 miles from downtown atlanta (on the west side of town) and was told the radio shack double-bow-tie would do me just fine. I got the 75 ohm adapter, plugged it in, and all i can get is NBC. it looks FANTASTIC. Trouble is, that's all i'm getting. It's picking up some very snowy analogs, but no other digitals. I would really prefer an indoor antenna, especially since i'm so close to town. Are there some powered indoor antennas someone can recommend that might help, or does it sound like outdoor is my only solution (since the antenna i have supposedly works as good if not better than outdoor antennas).
thanks!
thanks!
