DanielM
- Jul 5, 2002
ok I recently had a tech over to fix my tv overscan,picture centering and convergence all done pretty good or as good as a non isf tech will do the picture was damn good so I decided to upgrade from my tosh sd2109 to a
panny rp82..ok time to check out avia and redo what needs to be done....hmm the tech set overscan with the tosh and avia to 5-6% fine great now with the rp82 the overscan is down to 3-4% and there are picture sizing and centering as well as convergence issues nothing major mind you BUT if I were to call the the manf and try to get a tech over Im pretty sure the tech would say all is good and refuse work saying it meets spec...any ideas???
