HDR10 VS Dolby Vision (1 Viewer)
Xero Tolerance
Matthew
Hi guys, new to the forum. I like to think I’m pretty well versed in home theater stuff but this ones got me a bit stumped. I’m running an Onkyo TX-NR 777 receiver, LG UBK90 player and an LG OLEDC8. Humble opinion, HDR10 looks much better than Dolby Vision through my set up but most discs I play default to DV even though it says they’re in both formats. I’ve checked what I believe to be every setting but can’t find a way to default it to HDR10. Does anyone know of a fix or way around this? Thanks for the help!
JohnRice
Bounded In a Nutshell
A Mile High
With an OLED TV, DV really should be the best reproduction, if the TV is properly calibrated. That's the rub though, calibration.
Some UHD players have a menu setting to disable DV. The other option is to replace your player with a Panasonic UB420, which doesn't have DV.
Similar Threads
davidperk49
