HDMI Video Pass Through Only (Hook up questions) (1 Viewer)
kayo35
kurt knewitz
I have heard two theories on hooking up my Onkyo HT-S5100 receiver (HDMI pass through only) to a DVD and DVR to a Samsung Plasma.
One side says to hook up the following:
DVD via HDMI to Onkyo
DVR via HDMI to Onkyo
Onkyo via HDMI to Plasma
plus...
DVD via Optical audio to Onkyo (corresponding)
DVR via Optical audio to Onkyo
No Optical audio required from Onkyo to Plasma (supposedly)
The other theory is as follows...
then for audio....
Plasma via Optical audio (out) to Onkyo audio optical input
What is the correct way to hook this up? I am so confused?????
So my real question For Audio is as follows:
1. Do I run the Optical for audio from the DVD to the Onkyo and from the DVR to the Onkyo or.....
2. Do I just leave the DVD and DVR connected with only HDMI and run the Optical from the Plasma (out) to the audio (in) on the Onkyo?
Would either of these two scenarios work?
Would it be better to connect each of my devices (DVD/DVR) direct to the Plasma and bypass the Onkyo and only connect the Plasma (out) to the Onkyo via optical for sound?
Would running my DVD/DVR through the Onkyo via HDMI cause any problems with video quality.
Robert_J
Mississippi
HDMI is a digital signal. You either get the best picture quality or you get nothing. There is very little in between.
And speaking of HDMI. The $100+ HDMI cables from Best Buy will give you the exact same picture quality as the $5 HDMI cables from Monoprice. Same with the digital audio cables.
-Robert
Latest posts
daxlakin
