James_SCEA
- Sep 19, 2003
Hi all,
I was wondering if any of you are aware of any limitations on converting HDMI to DVI or visa versa. I have read in a couple of forums and on Audioholics.Com that you may not necessarily get the same performance as you would if you would run the straight connection without using a converter/adaptor or conversion cable.
Thanks in advance,
JC
Thanks in advance,
JC
