Herbie_Wilson
- Feb 6, 2006
Hi HT experts. This is my very first post, so greetings to you all.
I'm experiencing something unexpected with my new home theater. It's frustrating the heck out of me. Here is a list of the equipment in question:
* Hitachi 42" plasma (42HDF52)
* Samsung HD-upscaling DVD-HD755
* HDMI-to-DVI adapter
First off, I think it's ridiculous that, to achieve 720p/1080i resolution from the DVD player, you MUST use the HDMI cable...when component is fully capable of 1080i. I'm sure there's many posts and gripes to go along with mine.
Unfortunately, this TV does not have an native HDMI input, so I'm forced to use DVI to achieve the upscaling.
On to the problem...when I connect the supplied HDMI cable (came with the DVD player) with the HDMI-to-DVI adapter to the TV, it works fine for a bit (+/- 5 minutes). The resolution looks great, but then sure enough, the TV loses signal. The green LED on the front turns to yellow. I also noticed when using the DVI input on the TV, that p.mode (cinema, dynamic, etc) does not work (is this normal?)
Has anyone else ever seen this, and is there a resolution, besides having to upgrade the plasma to one with native HDMI input(s)?
Any suggestions would be greatly appreciated!
Thanks in advance,
Herbie
Thanks in advance,
Herbie
