HDMI Question
Discussion in 'Home Theater Projects' started by Bob_Lawrance, Jul 18, 2006.
  1. Bob_Lawrance
    Bob_Lawrance Stunt Coordinator
    Apr 14, 2002
    163
    Does HDMI carry the audio signal as well?
  2. Paul Anthony
    Paul Anthony Stunt Coordinator
    Jun 30, 1997
    169
    Yes.
  3. Bob_Lawrance
    Apr 14, 2002
    163
    So if I use a HDMI cable for my HDTV box do I run a digital cable for the surround sound?
  4. Alon Goldberg
    Alon Goldberg Screenwriter
    Jul 10, 2006
    1,131
    Hi Bob - HDMI combines video and multi-channel audio into a single cable. However, most TV's will not pass DD5.1, so I would typically recommend running HDMI from your digital box into your TV, and running seperate optical audio or digital coax into your receiver for surround sound.
  5. Bob_Lawrance
    Apr 14, 2002
    163
    Thanks Alon
    That is what I thought but just wanted to make sure.
    Do you think it would be worth switching from Component cable to the HDMI with my HDTV digital box?
  6. Alon Goldberg
    Jul 10, 2006
    1,131
    Hi Bob - HDMI was not designed to provide superior picture quality to component video. They should really be considered as "equals" in terms of PQ. Any differences you see are likely due to differences in equipment or the way the various inputs are calibrated (or not calibrated) on your TV, not the connector.
    However, HDMI may provide a superior picture when viewed on a fixed pixel display (like LCD, DLP, Plasma, LCoS) since these are digital displays, so the signal remains digital "all the way". CRT-based TVs are analog, therefore a superior picture is less likely on HD inputs since the D/A conversion must take place somewhere in the chain.
  7. Bob_Lawrance
    Apr 14, 2002
    163
    So I would probalby then stay with my component as I have a HDTV rear projection TV not LCD TV.
    Thanks for the information Alon.
  8. Bob_Lawrance
    Apr 14, 2002
    163
