shane7x38
- Nov 20, 2006
- Shane
Hi all,
I recently purchased a budget home theater system, consisting of the following components:
Syntax Olevia LT42HVi 42" LCD TV
Sony HT-DDW900 Home Theater system
The TV has 2 HDMI connections, along with the usual component/composite connections.
The receiver has some basic connections, including an HDMI "Monitor Out" connection.
I'm very new to this, and have been learning as I go...
I have my DVD player (and Playstation 2) connected to the receiver using component cables. The sound works fine when I select either device on the receiver. My problem is that no video is displayed on the TV. I have a Male-Male HDMI cable plugged into the HDMI out on the receiver, and plugged into one of the HDMI connections on the TV.
I choose "HDMI" as the Source on the TV, and verify that the receiver has the correct device selected, but alas, no video at all. The sound continues to work perfectly.
I have throughly scoured Sony's Support website, and both my TV and receiver manuals, but haven't been able to come up with any answers as to why no video is displayed.
What I'm looking for are any ideas about why it's not working. Possible theories I've come up with (forgive my ignorance) are as follows:
-Compatibility problems (different HDMI versions on the receiver and TV?)
-Maybe HDMI output only works for HDMI inputs? For example, if I connect the DVD player to the receiver via HDMI, then HDMI output to the TV will work. Because I am using component cables for the time being, maybe I would need to use component cables for the output from the receiver to the TV as well?
Sorry about the long first post...I figured too much is better than too little.
Thanks for your help in advance!
TV inputs/outputs:
Receiver inputs/outputs:
TV inputs/outputs:
