hdmi not working on 34hf84
Discussion in 'Displays' started by arv, Dec 27, 2005.
  1. arv
    arv Auditioning
    Dec 27, 2005
    I've had it for over a year and it's worked fine. I'm using a harmony remote and when I turn on the tv I see the picture for a second, then it goes blank. I've switched it manually, checked the connection and unplugged and plugged it back and the same thing happens. I only see thepic for a second?
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Another HDMI source does the same thing? If so, sounds like some odd true malfunction in the display.
    I would not rule out the source component either though. being so new, hard to rule out the cable(s) as well.
