I have a Vizio TV with an HDMI line from my BOSE VS2 splitter to the HDMI input which runs from the built in unit through the wall to the TV mounted on the wall. About three months ago, I lost the video signal. After replacing several lines, a new VS2, etc. I found running an HDMI line from the VS2 to the HDMI input on the TV outside the wall, I get a signal. The only problem is, the wire is in plain sight. So, I assumed it was the HDMI line behind the wall was "bad." It's very difficult to do, but I had a new HDMI line run through the wall and even mounted a new TV and...the same problem happened. NO SIGNAL with the line in the wall, but perfect when I plug an HDMI line in the exact same input on the Bose VS2 and Vizio TV. It's a perfect picture. Is there something going on in the walls? There is some basic wiring in there, but nothing special. The only thing close to the HDMI cable are some Bose speaker wires. Has anyone ever experienced a loss of signal like this and what can I do? I would appreciate any help.
