Aaron Schmitt
- May 26, 1999
I didn't want to post a new topic on this, but I didn't see my issue covered in the other HDMI error threads.
I just picked up an HD-A!, and I'm having an issue with HDMI error 1, with a Sony 42WE655 Wega. When I first set everything up, I could get into the menus and make all the adjustments there, and I would see the No Disk message when there wasn't a disk in the drive. When I put in an HD-DVD, it would try to load, the screen would flash a couple of times, then the HDMI Error 1 message would appear on the player.
I've spent the last few hours trying different things, and downloading the 1.4 firmware update in an effort to troubleshoot this issue. With help on another forum (lcvg.com/forum). I've tried:
- Turning on the TV and setting the input, then turning on the HD-DVD player. Also turning on the player and then the TV.
- Using a Standard DVD (still get the HDMI error after loading)
- Powering everything down, unplugging both the TV and the player, then after a minute or so plugged in the TV and powered it up, then the player and powered it up.
- Setting the Voutput to component, powering down the player, unplugging it, waiting for a minute or so, plugging it back in, power on, change Voutput to HDMI. (This has got me to the state where I can't even see the menus over the HDMI output now.)
I'm running out of ideas to try before calling Toshiba and Sony's support. Any other suggestions for things I can try?
Aaron
Aaron
