HDMI cat5/6 extender with IR (1 Viewer)
kossuth
Jason
First post. Looking for recommendations for an HDMI cat5/6 extender with IR integrated. I would prefer a unit that is sized for a single or dual gang outlet box. I’ve seen a bunch of stuff on amazon but other than going by reviews for folks that have had real world experience with components.
The TV hangs above a fireplace and the rest of the components are located in another part of the room thus the desire for IR.
Thanks.
xx Brian xx
Brian
I use this:
HDbaseT Extender Kit HDR Hdmi 2.0B 18GBPS 4K @ 60hz UltraHD YUV 4:4:4 Uncompressed 230FT 70M Transmitter Receiver IR RS232 (Cat5e or Cat6) HDCP2.2 Hdtv Control4 Savant Home Automation 4k2k
https://www.amazon.com/gp/product/B0754K17HM/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
It does Dolby Vision with no problem and can do IR in either direction. It doesn't install in a gang box, it is mounted behind my TV and the other one is in the smart closet.
Brian
Reddevil_23
