HDMI Cables
Discussion in 'Accessories, Cables, and Remotes' started by Chris Huber, Aug 29, 2006.
  1. Chris Huber
    Chris Huber Second Unit
    Jan 2, 2003
    416
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    http://www.bluejeanscable.com/store/dvi/index.htm
    Only a few dollars more, the owner is a member, has lots of happy customers, and will return your money if you dont like the cables.
    My concern is that the Optimized cable LOOKS like the wire is very thin compared to the plug. While I dont care about the wire - having a stiffer/thicker insulation provides more strain relief and could mean a bit of better shielding.
    For short runs in a tidy rack - this does not matter. But pushing 15-20 ft, it could make a difference.
    (and it could just be the picture) [​IMG]
    Sadly - there is no frequency-response chart for digital HDMI/DVI cables. So there is no technical info to base an opinion.
    I'd spend the $21.50 at BlueJeans instead of $15.50 for the Optimzie - just because I trust BlueJeans.
  3. Chris Huber
    Jan 2, 2003
    416
    Ty
