John Doh
- Jun 24, 2003
On the Sammy DVD player (931 I think) it says it has DVD-Audio and HDCD capability. Is HDCD the same as SACD? Thanks!
HDCD sounds like it could've been a winner except that SACD and DVD-A came along.FWIW, there was an article years ago in Audio magazine (now defunct) that analysed wave forms that were encoded with HDCD vs. standard redbook.
IIRC, they concluded that it was not all its cracked up to be, and actually added distortion to the signal. I don't know if there was any conclusion on whether or not it sounded better, but they had real issues with processing.
Having never owned a HDCD capable device before last Friday, I have never listened to a HDCD disc correctly decoded. Now that I do (a NAD 762 receiver) I need to go through my discs and find out which are encoded and give them a listen.
Personally, I do have SACD. I expect any improvement HDCD may make to be minor compared to what a true hi-rez format can do.
BGL
IIRC, they concluded that it was not all its cracked up to be, and actually added distortion to the signal. I don't know if there was any conclusion on whether or not it sounded better, but they had real issues with the processing.
BGL
