HD15 cable question?
Discussion in 'Accessories, Cables, and Remotes' started by chris elsing, Sep 13, 2005.
  1. chris elsing
    chris elsing Auditioning
    Sep 6, 2005
    2
    Is there a hd15 cable that has component connections on one end? I'm getting a projector that has a hd15 cable connection. Any input would be great.
  2. Leo Kerr
    Leo Kerr Screenwriter
    May 10, 1999
    1,698
    There are cables that have an HD-15 at one end and 5 RCA or 5 BNC cables at the other end, yes.
    PCs put out RGB over their HD-15s. Some projectors have a selectable 'component/rgb' setting for the HD15 port; make sure yours does.
    But yes, you can get a cable as you describe it.
    Leo
  3. DougRuss
    DougRuss Stunt Coordinator
    Oct 3, 2001
    195
    Check out one of the Forum Sponsors :
    RAM
