HD via Time warner cable, Finally up and running in Tampa Bay!!!
Discussion in 'Archived Threads 2001-2004' started by Rich Kraus, Feb 18, 2002.
  1. Rich Kraus
    Rich Kraus Stunt Coordinator
    May 3, 2000
    209
    I just finished watching charlies angles in HD with 5.1 audio, via my new SA explorer 3100HD cable box!
    time warner tampa bay has finally stepped up and has begun the rollout of HD STB's to consumers!
    picture is nice (comments on HBO's cropping withheld [​IMG] )
    sound was fine.
    they are sending out hbo and showtime currently, but they tell me that local network programming is "comming soon" along with other hd feeds like discovery channel.
    whoppee! i have HD cable!
  2. Rich Kraus
    May 3, 2000
    209
    update: found out today that there are "test" channels hiddin way up in the channel 800 range for the local networks.
    im watching olympic ice hocky in hd right now!
  3. JonBouche
    JonBouche Agent
    Feb 12, 2002
    38
    Rich,
    I have Time Warner HD here in Raleigh. I've had it for about 4 months and the programming that is in actual HD is stunning! There are 5 local stations with HD channels and then HBO and Showtime.
    What are the actual test channel numbers that you are referring to? I would like to see if I can get them here.
    Good luck!
  4. Rich Kraus
    May 3, 2000
    209
    thay also used to test the hd hbo and sho on 900 and 901.
  5. Yohan Pamudji
    Yohan Pamudji Second Unit
    Apr 3, 2001
    492
    110
    Lucky bastards...
    I called my local Time Warner, and the tech thought that it would be at least a couple of years before we get HD [​IMG]
  6. ManojM
    ManojM Stunt Coordinator
    Feb 13, 2002
    242
    They are supposedly implementing HD cable at Time Warner San Diego in the second quarter of this year. From what I understand from talking to people in TW San Diego, TW-AOL is starting to take HD cable rollout more seriously and they are becoming more aggressive about it. I am hoping to get my HD box in April-May.
  7. Rich Kraus
    May 3, 2000
    209
    for what its worth, the TW guys over here have been telling me its "our next project" or "its right arround the corner" since mid '99 when they first started testing in the area.
    dont hold your breath too long [​IMG]
  8. Ted Ross
    Ted Ross Second Unit
    Dec 13, 2001
    394
    Do these boxes do 3:2 pulldown?
  9. Dave Mack
    Dave Mack Producer
    Jan 28, 2002
    4,668
    4
    If I'm not mistaken, HD is a 1080interlaced pic. NOT progressive, therefore there is no putting of fields together, hence no need to do 3:2 pulldown to combine fields. If I'm wrong, let the flames begin!!!!
    [​IMG] D
  10. Ted Ross
    Dec 13, 2001
    394
    Sorry, what I ment was on the the non-hd channels(which is the majority, right now)does the box have an internal line doubler with 3:2 pulldown?
