HD Reception (1 Viewer)
Citizen87645
Cameron Yee
I live on a corner with heavy traffic in the mornings and evenings (live near a series of schools), which results in RF signal interference (can anyone explain this?). With regular TV it's not a big deal - picture is obviously affected but I don't lose the signal like with digital. The drop outs on HD are a little annoying. Is there anything I can do to boost the signal or make it more stable? I looked a bit into pre-amps but I'm not sure if this is the right route. I just use an indoor bowtie antenna.
BTW, when I had a Primestar system the same thing would happen. A loud car would go by and the signal would drop out.
Patrick Sun
You could try a $20 10dB antenna booster (Radio Shack or Home Depot should have them in stock). The more gain you need, the more expensive the boosters will be.
Craig Robertson
an external antenna would probably cure the problem, but i understand that's not always possible. raising the height of the indoor one as much as possible, say to a second floor if you have one, should help.
SeanA
You may want to try the Jensen TV940 antenna. It has separate built-in boosters for UHF and VHF, and the antenna position is programmable. I have had very good results with it and I live in the first floor of a two-story apartment building and near a moderately busy street. Drop-outs have been rare.
webbhcjr
