HD Reception on Samsung 351
Discussion in 'Displays' started by Ken_Smith, Nov 10, 2003.
  1. Ken_Smith
    Ken_Smith Auditioning
    Mar 3, 2003
    Question regarding the ota reception on Samsung T351: I just spent the weekend getting my Sony 42WE610 / Samsung T351 working with a couple of indoor antennas. I have 2 stations were I get a signal strength of 8 but yet have no picture. By switching to a different indoor antenna, the strength drops down to 6-7 and I start receiving a picture however with dropouts. Can you have too strong of a signal on a digital signal? Is there a way to keep the strong signal and still get a stable picture?
    Thanks for your help!
  2. Mitch_J
    Mitch_J Stunt Coordinator
    Oct 16, 2003
    129
    bump?
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    I don't think you have to high of a signal. Just a quirk that it gives you a signal strength of 8 and no picture.
    Just keep playing with your placement, I think you will get it all stable eventually.
    PS: Reflections can cause exactly this phenom. You would get good strength, but the digital cannot be extracted.
  4. Mitch_J
    Oct 16, 2003
    129
    Thanks John. I bumped this because I've just gotten myself the same HDTV tuner and I'm having similar problems. I was curious as to whether it was due to antenna location or a quirk of the Sammy 351.
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    I'd keep try'n with the placement.
    I did in the end go with the Zenith HDV-420 because many listed it as having better sensativity than the Samsungs.
    Many of the Samsung OTA owners, seem to indicate they had to absolutely go with an outdoor antenna for good performance.
    Signal strength without a picture, almost always indicates seriosu reflections are beign recieved, and can be minimized through trial and error placement.
    Took me weeks to find just that spot, where all 6 of my channels get receieved with some having only minor intermittent dropout issues.
