Shawn C
- May 15, 2001
Ok,
I am currently receiving HD from a Terk antenna mounted on my elliptical dish. Am I correct in assuming that the stronger signal I get, the better picture I will get? Is it like my satellite when you only have a signal strength in the 70's, you generally get a blotchy picture due to the incomplete signal and the MPEG compression?
Or, am I wrong and it's really an all-or-nothing deal? The reason I ask is that FOX NBC and ABC, for me, look REALLY bad. CBS and PBS look very good. This are the same results I got with NON-HD signals as well. Should I be looking for a better antenna?
(FOX and NBC aren't broadcasting HD content in my area, but are trasmitting an up-converted signal digitally)
