HD OTA reception
Discussion in 'Archived Threads 2001-2004' started by Brad Newton, Aug 27, 2001.
  1. Brad Newton
    Brad Newton Second Unit
    Aug 14, 2001
    382
    When this becomes a reality in my area......will I have to replace my current OTA antenna? Will my older tv's be able to receive this higher quality information?
  2. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    Since most digital channals are uhf, as long as your current ota antanna is for uhf also you should be ok...With your current analong TVs you will need a set top box to convert the digital signal to analog for your old analog TV's
  3. PS Nystrom
    PS Nystrom Second Unit
    Jan 27, 1999
    444
    How far can I be and still receive a signal? I'm about 60 miles from Los Angeles and am very tempted to get the Samsung OTA STB. My only concern is if I'll be getting a signal. Is anyone here getting OTA HDTV more than a few miles from LA?
    Pieter
  4. Phil A
    Phil A Producer
    Oct 1, 2000
    3,186
    44
    1,610
    Central FL
    Phil
    I have the Samsung unit but not familiar with your area. As long as there are no mountains or other obstructions in the way, a good outdoor antenna with a preampflier (amplifies the signal vs. a distribution amp) it should not be a problem. You probably want to talk to someone who installs (and knows what they are doing) in your area. Channel Master carries a wide variety of products and also has distributors all over, www.channelmaster.com.
  5. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    titantv.com
    has a 'calculator' that will give you a recommended antenna size depending upon your distance
    that should give you an idea
