HD OTA in SF Bay Area
Discussion in 'Playback Devices' started by Richard_Brodsky, Jun 26, 2006.
  1. Richard_Brodsky
    May 4, 2003
    41
    I'm getting a new HR10-250 (Directv HD Tivo ) installed tomorrow along with an OTA antenna. Does anyone know what to expect in terms of HD reception for my local channels? I am in Novato, CA (Marin County- SF Bay Area)
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    If you get your local analog channels decently with an antenna then the digital ones should be fine. If you currently do not use an antenna you might check with some of your neighbors who do to see if they are happy with their analog reception.
    This thread will probably soon be moved to the Audio/Video Sources forum, by the way.
  3. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    Richard
    Everything on the Antenna on Twin Peaks as long as you have enough gain.
    NBC CH11 is in South San Jose and I can't get it from the City on my 3rd story roof antenna.
    Doubt if you need a rotor since they are all on the same structure
    Good Luck!
    Grant
  4. Richard_Brodsky
    May 4, 2003
    41
    The DirectV installer wouldn't even bother installing the antenna for me. He said there was was no way I would get any OTA reception. : > (
