HD-DVD on a regular TV
Discussion in 'Blu-ray and UHD' started by Yumbo, May 1, 2006.
  1. Yumbo
    Yumbo Cinematographer
    Sep 13, 1999
    2,227
    Does it work?
    Down rezzed?
    Haven't read anything in particular.
    Or is it ONLY for those with HD screens?
  2. Will d s
    Will d s Stunt Coordinator
    Jun 21, 2004
    75
    No it will not work since your tv will not support the resolution.
  3. Aaron_Brez
    Aaron_Brez Supporting Actor
    Apr 22, 2000
    792
    Not true. They downconvert.
  4. Sam Davatchi
    Sam Davatchi Producer
    Sep 15, 1999
    3,150
    There is no point to it!
  5. Joseph Bolus
    Joseph Bolus Cinematographer
    Feb 4, 1999
    2,470
    207
    It actually *will* work on regular standard definition TV's via it's s-video and/or composite video outputs. And there *is* a slight benefit: less compression artifacts present in the transfer (no EE, "stairstepping", etc.), and slightly better black level.
    But if all you have is a 4:3 aspect ratio standard definition display device, it's probably not worth the investment at this moment. Put the money in stepping up to a 16:9 ED or HD display device instead.
    (By the way, most 16:9 Enhanced Definition displays can benefit greatly from HD-DVD transfers, even though the display is having to "downrez" the 1080i to 480p. This is mainly due to the fact that most ED plasma sets expect to be fed a 1080i source and therefore do a good job at deinterlacing/scaling that particular source. Most also do a commendable job of scaling 480i up to 480p. You can pick up 16:9 42" ED plasma displays now for around $1000.)
  6. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,218
    Actually, there might just be a point to it, but it's iffy. From what I understand of color sampling (which isn't much), only the luminance part of the picture (Y) is sampled at the "full" 720x480 frame size. The two chrominance channels (Pr, Pb) are sampled at half resolution.
    source
    I understand that this scheme is also used for HD-DVD. Depending on how the downscaling feature works, it's possible that the equivalent of 480i 4:4:4 video could be output, which should result in sharper, more vivid colors. But you may not be able to detect a difference.
  7. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Chris, I'm closing your identical thread query in the hardware area. Do no post the same thing twice in multiple areas. Thanks.
