HD A20 sound problem (1 Viewer)
Camper
Florida
David Dennis
My HD A20 will not send sound from a HD-DVD disc via HDMI or Optical cable but will send sound from a standard DVD through both.
This problem just appeared after 10 months of owning the machine.
I haven't recently installed firmware or made any adjustments.
Has anyone hard of a problem like this or have any ideas short of a trip to the shop to fix it?
Thanks to anyone!!!
Clinton McClure
Rocket Science Department
Central Arkansas
Clint
Sounds like a setting for HD-DVD playback has been changed. Make sure (if there are separate settings) the audio out setting for HD-DVD is set the same as SD-DVD. Beside that I can't offer any explanation. Perhaps you need to reload your most recent firmware. I have an HD-A1 which would have a similar menu, however I'm away from home and can't recall the menu choices.
Kastelman
Eric Kastel
i have exactly the same problem....do u have a answer for me....please
i put the last firware ver.4.0 and i lost the sound now with the regular DVD
TheThrillisgone
