HD-931 - No Dolby Digital, only Prologic II
Discussion in 'Playback Devices' started by Shane Morales, Dec 25, 2003.
  1. Shane Morales
    Shane Morales Second Unit
    Jul 9, 2003
    433
    DVD Player: Samsung DVD HD-931
    Reciever: Denon 3803
    Connection: Digital Coax
    This a weird thing. My receiver doesn't recognize when my HD-931 is running Dolby Digital 5.1. It sets itself to Prologic II and won't even give an option for Dolby Digital. If the DVD player is running a DTS soundtrack then the receiver will detect that and switch to DTS.
    If I play the same movie with Dolby Digital 5.1 on my other DVD player (hooked up to the reciever with optical) the receiver detects the Dolby Digital right away. Same with DTS. No problem.
    I can't figure it out. Not the receiver because it works fine with another DVD player. Not the cable because it works fine with DTS. I don't know about the DVD player, though. If it were busted then wouldn't it just not play any sound at all under Dolby Digital?
    Any ideas?
  2. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,763
    488
    9,110
    Do you have the DVD player's audio output set to PCM or bitstream? Bitstream will output the DD5.1 audio through the digital audio output. PCM will send out the 2-channel (or DPL) audio through the digital audio output.
  3. Mike Capulli
    Mike Capulli Stunt Coordinator
    Sep 12, 2002
    76
    when I had the 931 the DD worked fine via optical. It was just constantly out of sync which is why I returned it.
  4. Shane Morales
    Jul 9, 2003
    433
    Patrick,
    Thanks, that was it. It was set to PCM. Changed it to Bitstream and it's working fine now.
