Having problems with the 16:9 calculations
Discussion in 'Displays' started by Monte Montemayo, Aug 14, 2004.
  1. Monte Montemayo
    Aug 8, 2004
    28
    Hey there, I am building a 16:9 screen but I’m looking for a formula so I know how to measure the screen. Essentially, I’d like a 100” screen but I’m confused on the measurements. I know I should have paid attention in 9th grade math class. So much for the saying, “I’ll never use this junk”.
  2. DaveGTP
    DaveGTP Cinematographer
    Jul 24, 2002
    2,096
    Hypotenuse = diagonal of a triangle.
    Using a right hand tringle to figure out the diagonal of a square:
    Pythagorean theorem:
    side1 squared + side2 squared = hypotenuse squared
    x^2 + y^2 = z^2
    so you want z = 100
    so you want the square root of x^2 + y^2 to come out to 100.
    and you want 16:9 ratio between x and y --> so pick a number for y, multiply it by 1.7777, and plug into the equation.
    Looks like about 50" x 88.88" to me...that comes out to 101.986" diagonal. I think you could elimate the squares from the equation to come up with it exactly, but that would be too much math... [​IMG]
    49" x 87.11" = 99.94" diagonal
    Someone else to check my math would be appreciated - too much calculus damaged my algebra skills [​IMG]
    That doesn't include a frame...depending on how you are doing the frame. I don't have one at all yet.
    My screen was done more slapshod for my weak carpentry skills and equipment - I just used nice even hunks of wood. My screen is 51" x 72" --> 1.41:1 ... and I shoot 4:3 onto it - it is too big for the current setup. Maybe in the new house...
  3. Monte Montemayo
    Aug 8, 2004
    28
    Thanks! This is very helpful. I have my EXCEL program up trying to figure all this out. I appreciate this advice.
  4. Monte Montemayo
    Aug 8, 2004
    28
    I checked your math and you are correct. Well actually its 99.946 but close enough for Gov'mt work. [​IMG]
  5. Scott Dautel
    Scott Dautel Second Unit
    Oct 6, 1998
    471
    There's an easier way.....
    For any 16:9 screen the diagonal is 18.36 (thank you pythagorus).
    This is the only number you need to remember.
    The ratio's will always work.
    So for a 100" diagonal ...
    height is 100*(9/18.36) = 49.02"
    width is 100*(16/18.36) = 87.15"
    Another example ... say you have 85" of width to work with:
    diagonal = 85*(18.36/16) = 97.54"
    Scott
  6. Monte Montemayo
    Aug 8, 2004
    28
    Ahhh.. there's always a secret. Too bad you didn't sit next to me in Math Class. [​IMG]
  7. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I have the easiest way: Projectorcentral.com
